Greenwood wing removal
Old 06-20-2013, 01:14 PM
jeff84red
jeff84red's Avatar
Default Greenwood wing removal
I bought this car with the wing a few years ago and want to remove. I have a new rear cover from a donor car so looking for best method to remove the wing. I dont have the original installation instructions so looking for a few tips to remove the wing and rear cover. Thanks!
Old 06-20-2013, 03:13 PM
LT4POWR
LT4POWR's Avatar
I don't know how to remove it... but I applaued you for removing it
Old 06-20-2013, 03:29 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Remove a couple of the rear taillights and go through the holes.
Old 06-20-2013, 03:54 PM
GREGGPENN
GREGGPENN's Avatar
C4 of Year Winner (appearance mods) 2019
There are "archived" posts with this info. IIRC, go thru the license plate (hole) to remove in the inner tail lights. Then, the outer ones. Thru these "access points", you'll be able to reach up and feel the 10mm/7mm nuts around the edge of the bumper. These all have to be removed to pull the cover. You also have braces under the rear AND the wheel well has to be detached (where it connects to the bumper).
A true Greenwood, will have posts (rods) jutting from the spoiler down to the inner crash bar. You MAY need to undo those fasteners before disassembly is possible.
You now have more info that the first time I pulled my rear bumper. So...GET AFTER IT!!!
Old 06-20-2013, 04:27 PM
jeff84red
jeff84red's Avatar
Thanks for the responses. Will put up pre and post pictures
Old 06-20-2013, 04:37 PM
GREGGPENN
GREGGPENN's Avatar
After removal, contact any bumper company in your area. Yellow pages should direct you. Even former chrome bumper replaters work on urethane now.
They should have the 2-part mix/filler to repair the holes -- assuming you don't have/want a new cover.
I'm wondering (and betting) you'll have marks on the panel in front of it too. Unless the legs are smaller than I remember.
(I never owned one....I just pretend to know about C4 stuff!)
To Greenwood wing removal
Quick Reply: Greenwood wing removal
