93 won't start and does not make any noise
Old 06-30-2013, 12:36 AM
Corkguy
Corkguy's Avatar
Default 93 won't start and does not make any noise
Drove my 93 Automatic today and it drove fine. Parked it and went back to start a couple hours later and nothing. I won't even try to crank there are no relay clicks, no celinod clicks just silence. It has power to the light, AC and radio they all work fine.
I putt a battery charger on it for a few hours and still nothing so its not low voltage.
I tried starting in park and neutral, shook the shift lever and still nothing.
Tried a second key and nothing.
I saw the other post in regards to the Starter Enable Relay but I don't hear any clicks inside the car.
Any ideas?
93 Automatic with 100,000 miles
Old 06-30-2013, 12:44 AM
vetteoz
vetteoz's Avatar
As noted in the other post you could jump the starter to confirm that it works
Originally Posted by Corkguy
Any ideas?
No power from Ign switch
Faulty enable relay
Faulty NSS
Vats related problem ; key, CCM , etc
Only individually checking each will confirm if operational
Old 07-01-2013, 04:31 PM
bill57g
1st Gear
bill57g's Avatar
I have a 96 vette and it's dong the same thing. took the driver's door panel off to adjust window and now it would crank. tried both keys.
bill
Old 07-01-2013, 08:14 PM
csthews
csthews's Avatar
Still can be a bad battery or bad battery connection.
To 93 won't start and does not make any noise
Quick Reply: 93 won't start and does not make any noise
