A/C issue-90 all of a sudden!
Old 07-26-2013, 08:41 AM
MZee
MZee's Avatar
Default A/C issue-90 all of a sudden!
Well, this forum sure helped me with the Teflon stub axle and bearing issue, instaed of replacing unneeded new u joints, people here suggested I replace the washer and the creaking noise is gone, runs like a top now but,
my a/c stopped , blows hot, I had it recharged yesterday, blew cold, two hours later, hot.
How could a leak develop that fast, all season it blew cold cold up til now???????????????????????????????????
MZee
Old 07-26-2013, 09:00 AM
kimmer
kimmer's Avatar
C4 of the Year Finalist
Blend doors may not be working.
Old 07-26-2013, 09:41 AM
rli7275
rli7275's Avatar
That certainly does appear to be a leak. Only thing is a leak of that magnitude should be easy to spot. Who recharged it? If it's leaking that bad it won't draw down a vacuum. While it is possible there were two issues and now it's something else like the blend doors as said, it did get cold after recharge. I would have the shop put dye in it to find the leak although a two hour leak should be obvious(oil accumulation,hissing noise) or such.Freon is expensive even R134 you don't want to keep that up.
Old 07-26-2013, 10:58 AM
JMelton
JMelton's Avatar
This might sound dumb, but is the clutch engaging? If the rubber hub on the compressor is bad, it can make you think there is a problem someplace else because it will look like the compressor is turning, when in reality, it isn't.
My 96 did that to me. I could see and hear the clutch engage, but it blew hot air. Drove me crazy until I actually stuck my head down there and saw that the bolt that goes into the compressor shaft WASN'T spinning even though the compressor clutch was.
Old 07-26-2013, 01:12 PM
MZee
MZee's Avatar
Thanks, to answer, the garage mechanic shot it up, ran ice cold , drove it back to my place to drop it off, ice cold.
I got in it two hours later , boiling hot air. Blend doors, not too familiar with that.But I called there, now I have to drop it off, no car again, that's one day at a time for each issued.
Radio, stub washers, now AC.
That's it ,no other issue.
Old 07-26-2013, 01:19 PM
MZee
MZee's Avatar
Old 07-26-2013, 07:20 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Life is good.
But your C4 journey is never ending
To A/C issue-90 all of a sudden!
Quick Reply: A/C issue-90 all of a sudden!
