Fuel Pressure Regulator
Old 08-16-2013, 11:44 AM
HlhnEast
HlhnEast's Avatar
Default Fuel Pressure Regulator
Apparently my FPR hasnt been hooked up to any vacuum source. Where does it get vacuum from on an '85 L98? One of the ports at the back of the upper intake?
Old 08-16-2013, 12:42 PM
floridamale
floridamale's Avatar
The FPR gets vacuum from the rear side of thr plenum just above where the FPR is located there should be 2 ports there.
Old 08-16-2013, 01:24 PM
HlhnEast
HlhnEast's Avatar
Thanks! Thats what I thought. I have been trying to correct all the problems with this car as I find them. Its run fine for 5 years and I just finished the heads and found it.
Old 08-17-2013, 01:13 AM
Cliff Harris
Cliff Harris's Avatar
The front vacuum port of the two on the rear of the plenum connects to the fuel pressure regulator. If you still have your smog pump it also connects to the A.I.R. valves on the front of the engine.
Old 08-17-2013, 01:36 AM
vetteoz
vetteoz's Avatar
To Fuel Pressure Regulator
Quick Reply: Fuel Pressure Regulator
