-=Please Help - Need DFI Global file for 383 SuperRam!=-
(I posted this in the ECM Section also, but there doesnt seem to be much traffic in there!)
Hi,
I really need some help getting my DFI Programed! I first fired up my combo last year and my injectors were way to big (48lb) I also burnt thru a plug wire and the aftermath was a pan full of oil and gas, which led to a spun bearing or two. I don't want to do that again!!!
I have gotten the motor rebuilt, and this time I am using FMS 30lb Injectors!!
Here are my specs:
383 - Eagle Steel Crank
Eagle H-Beam Rods
SRP Forged pistons 9:1
AFR 190 heads 2.02/1.60
Comp Cams Roller Lifters
Comp Cams Roller Rockers
Crane Hyd. Roller Camshaft 222/230 Duration .509/.528 Lift 112 Lobe
SuperRam
Ling. 58mm TB
1 Bar Map
700R4 2600 Stall Non-Lockup
1 5/8" --> 3" headers --> Dual 2 1/2" --> Flowmaster 40's
I am running 40psi Fuel Pressure
I am looking for a Global File I can use to get this thing going. I used the utility to make a base fuel map, it seems to run ok, but I'm wondering if anyone has one I can take a peek at!
Any feedback would be great!!!
Bill
Hi,
Here are my specs:
Eagle H-Beam Rods
SuperRam
Ling. 58mm TB
1 Bar Map
Bill
Re: -=Please Help - Need DFI Global file for 383 SuperRam!=- (BillRed85)
914.478.1727 ask to speak to Job(pronounced JOBE) tell Him Jay with the blue vette from Connecticut told you to call. He is VERY knowledgeable. Tell him your combination and such so He has something under His hat which to judge. He did the DFI on my past two Mustangs(One did mid 11's the other, MID 7's!!)
Good luck.
Good luck.
Re: -=Please Help - Need DFI Global file for 383 SuperRam!=- (JD 90 383)
Jay,
I just spoke with Job this morning. He seems like a nice guy, but he wants me to pull my ecm and ship it to him so he can program it. I'm not that crazy about sending off my dfi computer, so I think I'm gonna pass. Thanks for the number though!
I was hoping I would find someone with a similar setup that could just e-mail me a global file.
Bill
Bill
As far as the drive is Bill,
It'd be worth it to pay Him a visit. He's EXTREMELY good at what He does.. Think on it.
Good luck.
Good luck.
