Best 383 LT1 stroker kit for Trick Flow 430HP
Hi guys,
I will buy Trick Flow 430HP top end engine kit and I was wondering, which 383 stroker kit is the best for me?
http://www.summitracing.com/parts/tfs-k304-430-400
My goal is about 500HP crank, so is something below good enough?
http://www.summitracing.com/parts/es...make/chevrolet
http://www.summitracing.com/parts/sc...make/chevrolet
Or it is better to go with forged pistons?
If your goal is 500hp, why are you buying a top end kit thats only gonna make 430hp? Your asking for disappointment using that kit on a 383.
A real 500hp engine from me gets all forged rotating assy. 450hp engines can get by with cast crank, SIR type rods and forged pistons. I personally don't like to use hyper pistons beyond 400hp.
Will
Will
My budget is unlimited I want about 500HP crank, so if somebody can write detail specification of parts I need to buy, that will be great
My idea was that with Trick Flow 430HP kit, Edelbrock Intake manifold http://www.summitracing.com/parts/edl-7109 , 58mm TB, CAI, Custom headers and complete exhaust, no cats, 383 stroker (or maybe 396 stroker) I can achieve 500HP crank.
I just read this article: LT1 Cylinder Head Comparison - GM High-Tech Performance Magazine
If I understood it, AFR heads which they used are AFR 1031
http://www.summitracing.com/parts/afr-1031/
Cam is 280XFI, but I can't decide which one of these, I think first one?
http://www.summitracing.com/parts/cca-08-467-8/
http://www.summitracing.com/parts/cca-12-467-8/
Also, these heads require stock LT1 inlet manifold (Not compatible with self-aligning rocker arms., designed for use with Generation II LT1 intake manifolds only.) , so Edelbrock LT4 IM is not in the game, if I understood it correctly.
Can I use this rocker arms with this combo?
http://www.summitracing.com/parts/tfs-31400513
Regarding gasket set, which kit I can use because I don't see on Summitracing that there is set for 383 ci, so can I use set from Trick Flow 430HP top end kit?
http://www.summitracing.com/parts/tfs-31400911/
Also, pushrods I can't buy at the same time, first I need to measure length, OK?
So, if I am right about these parts above , which stroker kit do you recommend?
Thanks a lot in advance.
Why?
Have you factored in extra $$ to upgrade the drive line to handle that level of power ?
500 at the crank = how much at the wheels ???
http://elliottsportworks.com/
Do your research.
Not too many recommendation for it out there over a stock or ported stock LT1 intake for much less than the $450 asking price
given the impressive results of this comparison
http://www.gmhightechperformance.com...ttle_body.html
http://forums.corvetteforum.com/1567770432-post7.html
Pro Dyno Tech tune, Crane Gold 1.6RR, SLP claw, 52mm TBI, EM Headers, Magnaflow 3"cats and X-pipe, Borla mufflers, AFR 195 heads, LT4 intake, LPE 219, E-waterpump, MSD opti, LTCC, 255lph fuelpump and AC delete got me 423rwhp and 396rwtq out of my 350. Going with a 383 and 210 comp ported heads with 1.7 rockers should get you 500 at the crank.
