1994 no cooling fans
Ok I've tried going through the posts but can't find the answer. Issue is no cooling fans at all. I jump the ALDL and fans don't run. I can jump each relay however and each fan runs. I checked fuse panel and big fuse under hood and they look ok. Ideas? Thanks!
I don't want to modify the system. I need to know if there are any additional troubleshooting procedures I can do to locate the problem. Thanks
the link includes a wiring schematic that I thought you could use in conjunction with a volt
meter to isolate your problem.
Ok I replaced the temp sensor/switch in the block (between plugs 2 and 6) and still no fans even when I jump diagnostic connector (pins 4 & 12). Like I said I can jump the relays by the shroud and fans come on. Any other ideas? Thanks
ECM/PCM. The temp sensor on the water pump (front) is the operational sensor:
http://www.corvettebuyers.com/c4_sen...formation.html
I replaced that one last year but I guess I need to check it. BTW it isn't throwing any codes like it did when that sensor went out originally? Thanks for any help.
