zz383 with mini ram fuel pressure
I ordered a zz383 from summit and a mini ram from tpis with 58mm throttle body and 30lb injectors. A set of tpis headers and a chip tuned for that set up. My question is what is the best setting for the fuel pressure regulator. I would really appreciate some help.
TPiS should advise the FP required for their tune
If the chip is programmed right , usually stock 43.5 psi.
In any case you should datalog it after you have it running so the tune can be tweaked
Not all tunes are perfect straight up for a particular combo
