No power at the "INST" posts in fuse panel.
Old 11-14-2013, 01:06 AM
jnorth
jnorth's Avatar
Default No power at the "INST" posts in fuse panel.
I have no lights on the console. The ones that the dimming lever on the headlight switch controls. first thing I checked was the fuse. Fuse was good but I didnt get power on either post no matter where the headlight switch or dimmer lever was. I'm not sure how to test the switch for proper switching between pins but i did find two pins that the resistance changed when i moved the dimming lever so i assume that part is functioning. Also, i replaced the dimmer rheostat that is located under the dash on the left side of the steering column. Is the switch the last option? Can I test it?
Old 11-14-2013, 11:23 PM
jnorth
jnorth's Avatar
Beuler?
Old 11-15-2013, 01:27 AM
ccrazor
ccrazor's Avatar
St. Jude Donor '08-'09
Not sure of your year but here is the drawing for an 84..
[IMG][/IMG]
If you are similar to this check the tail fuse, if its good that leaves the light switch..
To No power at the "INST" posts in fuse panel.
Quick Reply: No power at the "INST" posts in fuse panel.
