How do I access the Power Antenna on a 1990 Coupe
I need to adjust the mast height. It was replaced by the previous owner and won't go all the way down. It sticks up about 2-3 inches.
Re: How do I access the Power Antenna on a 1990 Coupe (chuckster)
I recently had to take mine out on my 88. If your is the same its just 2 screws on the bottom of the antenna and a ground strap screw on the mast cover. You can reach up under the rear quater and get to everything pretty easily. The pain part is taking the panels off inside the car to access the wiring and getting the grommet in and out.
