fuel squirting from pipe joint connected to drivers side fuel rail; 88 Corvette
Cruising
This is my first post here, guys. I have encountered an increasingly difficult issue here. On my 1988 Corvette I just bought a month ago, I am having fuel squirting out of the joint between the actual metal pipe and the bolt that holds the line into the back of the driver's side fuel rail. The line runs from there to in between the front two and back two injectors on the same side and has some sort of sensor that screws into the intake and has a connector on top similar to the connector for the injectors. I am trying to identify what this whole line and sensor thing is called. I'm usually a fairly adept mechanic, but this is my first vette, and I can't find anything online naming this part or where I can buy a replacement.
By the way, the o ring was bad on the fitting originally, but then I replaced it and now the o ring rolls back from its place every time I begin to screw it back in, but I still don't see how that can cause fuel to come from the joining of the pipe and the fitting because the o ring is just for the outside, and that's not where the fuel is coming from.
Please help me out guys (apologies for the length).
You need to rebuild your fuel rail. You can purchase an oring kit, pull it apart and replace all your Orings. If the injectors are stock I would replace them while you are in there.
Cruising
I will definitely look into getting those manuals and whatnot, guys. Just wondering what the name of the rail running from the cold start injector is called.
I finally fixed the problem by rounding off the sharp edges of the 45° bevel inside the bore and polishing it. A little lubrication on the O-ring and then it slipped right in and no more leaks.
Here's a picture. Item #107 was my problem:
You can try to find a cold start injector I'm not sure they serviced any longer. Or you can get one of these kits to remove the cold start injector.
http://www.ebay.com/itm/370791468159...84.m1438.l2649
