91 L98-Fuel Pressure leak down test.
What is the best way to check fuel pressure leak down on my 91 Vette?
With engine on, fuel rail pressure is 42psi but, with engine off the pressure drops to 20psi in about 2 minutes. Would pinching off the fuel return line after starting the engine and then shutting off the engine, determine if the injectors are leaking?
New Racetronix stock replacement fuel pump, 2 year old Bosch III injectors and new fuel pressure regulator diaphragm.
There is a fuel bypass valve in the fuel pump that sometimes leaks. To test that you do the leakdown test but pinch off the SUPPLY line.
Just because you replaced the fuel pressure regulator diaphragm doesn't mean it is not leaking. Pull off the vacuum line while the system is under pressure and see if fuel comes out of the FPR.
I wouldn't worry about it. Mine drops to zero in 10 seconds and runs fine.
Fuel pressure reads, 42psi with the FPR vacuum line removed engine running and 32psi with the vacuum line attached engine running.
The fuel pressure still bleeds down with either the fuel supply or return lines pinched off. Does this indicate leaking fuel injectors?...
Does it leak down with both pinched off at the same time? If so, yes it must be leaking at the injectors. Pump it up and pinch the supply, and watch.
Max G’s
I really don't think there's a problem because the engine starts, idles smooth and performs fine!...
I'll call Jon Banner tomorrow about the Bosch III's.
Unless you have all the original fuel injector clips installed do not pull the rail and pressurize it. The 40 psi will blow any none clipped injectors out and flood the engine bay quite quickly with raw gas. I have after market ones from FIC and they are not attached in any way to the rail.
