Need some help on what to do next
I have a 84 corvette with only 80k miles. I got it bone stock from a old gentleman who took extreme care of it. When I purchased it I did a few things, deleted the air pump, headman headers, magnaflow X pipe, corvette central magnaflow mufflers with lt1 tips, k&n air filter, comp cams 270h cam, comp cams valve spring and valve seals, replaced every gasket and put a new timing chain and gears, new fuel filter, changed trans filter and replaced fluid with b&M trick shift, also a new harmonic balancer, C5 wheels, corvette central lowering kit, ported and chopped intake manifold, and a hyper tech ecu chip. Ok I did all that at once and it starts and runs but it runs very rich, like cant stay in the garage because you can breath and it burns your eyes rich. I thought I may have had a wrong chip called hyper tech and gave them the numbers on the chip and it was correct and they even sent me another one and still the same thing. I been over everything, changed all the new lines and gaskets with another set of new gasket were I thought there could possibly be a leak and did not help. I am not a fan of this cross fire injection setup so since there is a issue with this fuel injection setup I been kicking around the idea of swapping it to a carb setup, or sell it and buy a older car but I do love this c4. I am wanting to put a 671 blower on something and people keep telling me that I can run one on this corvette 350 on low boost so I want to know if that's true? Also the pulleys just say how much underdrive they are for example it says 10.5% underdriven how do I know how much boost that is?
I should also add I did break the new cam and valve train in properly with comp cams break in oil additive with non synthetic oil, and the timing gears and timing chain install was done by a very reputable engine builder here in town.
So basically I want to know can this motor handle a low boost 671 blower along with the mods I have done so far, and how do you know how much boost each pulley is made for when its just gives under drive percentages.
Sorry for my lack of knowledge this is my first American v8 car, I mainly build and tune Volkswagen turbo diesel's but this corvette has changed me. Lets remember forums are to learn and to seek information from, so keep the criticisms and bashing to your self too many other tuner forums are bad about this lets keep this thread informative and clean.
I skipped most of your stuff because I don't have much time, but hyper tech chips are garbage. What you need is a tune. You changed the cam shaft which the computer cannot compensate for without a tune. Use tbichips.com, I was recommended to them because I have the old 870 ecu, I never used them though but they specialize in your computer. Good luck.
Installing a blower in an engine with 80K is kinda pointless unless you plan on rebuilding it...or wanting something that will last. Under-driving it is also pointless to me unless you just want it to look good.
I do not know what you mean about "ported and chopped" intake manifold. This does not make sense...because I know what a cross-fire intake looks like and I am not aware of it being able to be "chopped"
Depending on how much"porting" was done...or how slick it was "polished" ...if it was "polished" can cause a problem with the fuel not being able to be atomized well enough due to the casting texture is no longer there and it is slick as glass. This might make this engine a high RPM engine...and at idle it will possibly "load up" on raw un-atomized fuel and foul out the spark plugs.
I feel that you have a fuel pressure issue. I am betting that the injectors are dumping in fuel...due to a lack of sufficient pressure to allow the injectors to atomize the fuel. I also bet that it may take some time for the ECM to go into "CLOSED LOOP". And if it does go into closed loop...it may even go back into "OPEN LOOP". Possible installing a heated O2 sensor may be needed...but I am not there to read your data when the engine is running. Knowing your fuel pressure is VERY IMPORTANT.
DUB
DUB
671 on a Vette requires cutting the hood open + you will probably have trouble seeing around it.
My Deuce coupe with a 671 on a 350 with 64cc heads & flat top pistons .030 in the hole gave 10 lbs boost @ 18% under drive.
I used Dyers blower works for parts etc they are in Chicago far south side.
http://www.technovelocity.com/chevyh...rt_polish.html
That's the link to the intake porting I did step by step, I did not polish the intake ports.
Is a heated oxygen sensor something that's after market like get it from jegs or is it just another oem style one I can get from auto zone or advance.
Anyone have part numbers
I would need the o2 if I were to keep the cross fire setup and not put a blower on. Thanks for the info on the boost, if I do spring for the carbed blower setup I think I would go 5 psi to be safe
you Would Still Need It With Any type Of Fuel Injection, Blower Or Not. What You Need To Do Is Buy A Same Sized O2 Sensor, But For A Car That Uses Heated Sensors. The Sensor Wire Will Be Cut And Crimped To The sensor WIre On The Car. And splice The Other Wires To A Ground And Hot With Key On Or Engine Running.
If I am not mistaken...you can use the heated O2 sensor for a 1993 ZR-1. Sorry no part number right now. I believe it is a 3 wire sensor.
DUB
DUB
I don't know about that. I had a Procharger on my L-98 with 100,xxx on it and it was a beast. I have since put that engine without the blower in my t-bucket for over a year, sold the car and am putting the engine in my Hudson. All on the stock build. Keep your boost reasonable and your Fuel pressure (as you noted) correct.
The guy who took extreme care of the car must be thrilled by this story.
