Help with LT1/LT4 Compatibility.
Max G’s
My LT4 bottom end came apart and toasted the crank. So have been looking for a used engine and have found one to purchase. It is an LT1 from an 95. It has just been rebuilt and heads reconditioned. My questions are;
a) Is the bottom end, short block, the same?
b) Are the heads the same except for the roller rockers? I would like to just use the heads already on the engine and put the roller rockers on.
If there is anything else I should know please let me know.
Thanks L98TPI
Thanks L98TPI
Thanks L98TPI
Thanks L98TPI
Max G’s
So the heads and manifolds are not interchangeable? If not I will use my LT4 heads and manifold.
Max G’s
Grand Sport Registry lists several differences between LT4 & LT1 including Pistons, Timing set, Balancer ... etc... you could run the LT1 until you can repair LT4. You would need to watch not to over rev LT1.
One other question. What is the LT1 out of? If its anything besides a vette, ie. Camaro or Impala, it is a 2 bolt main, vs vettes having a 4 bolt main. Also, if its an impala, its cast iron heads.
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Also make sure its not a 4.3 Liter v8 out of a caprice.
That said, there are a lot of differences on the top AND bottom end. Crank, pistons, rings, etc. Sounds like you have most of it covered though.
Max G’s
I am going to take down to the short block and put the Heads,Cam, Intake, injectors, and etc from my LT4 onto the short block. I am going to add a road race oil pan and ATI Super Damper as well.
If anyone needs the heads and injectors and intake from the LT1, I will sale them at a good price. The heads were recon'd at time of rebuilt.
Spayed 4 bolt caps on the 2 bolt LT1's are actually stronger than the 4 bolt LT1's in Corvettes. You should have no issues with the 2 bolt mains. F-Body guys run them hard all the time and they live most of the time.
I would be willing to take that old broken LT4 to the dump for you and save you the trouble of taking the freshly rebuilt LT1 apart .....lol.....just offering
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I have both (95 LT1, and LT4). If you read the above mentioned link, you will see both are completely different. I remember the LT4 rods were stamped "LT4". The balancer are 100% different. I'd say the block is the same on cast iron. There are many other variations like the PCV lines, and no EGR on a 96. On the EGR is an easy fix, remove the plate, and bolt the 95 EGR on it.
This is a very informative thread; as I've got a trashed LT1 myself and am looking at the options available. If you've got an LT1 Camaro short block and LT4 heads and an LT4 Intake manifold; exactly what other parts would you need to make that combo work? No need to discuss the cam. Thanks!
Max G’s
Max G’s
