pulled these codes help
p0100
p0400
p1641
p1661
one code is maf, and one is egr, do i need to just replace them both or can i test them some how first..
thanks pastamike..
p0400
p1641
p1661
thanks pastamike..
Could be wiring , grounds , connections or the unit itself at fault
You need to work through the diagnostic flow chart for a code in the FSM to identify where the fault actually lies before throwing $$$ at it
Linked below is the diagnostic flowchart for a TPI car to give you a idea of how it works
http://www.chevythunder.com/maf_code_33.htm
Someone with a '96 may be able to put the diagnostics up for you if you don't have the FSM
( considered essential ownership if you want to wrench on your own car )
I have a 96. For the P0400, check out this thread where I have a pic and instructions. I repaired mine first. It lasted 2 months then the SES light came on again so I ordered a new AC Delco replacement. So far so good.
http://forums.corvetteforum.com/c4-t...-seslight.html
