Another 84 crossfire question
From what I understand a stock non ported X-fire system flows about 570 cfm So why wouldn't you be able to install it on a crate engine like the BLUEPRINT 355 CI with these specs for the top. it is advertised 310 hp and 360lbs tq. I know you wont get those results but.....
Cylinder Heads:
Blueprint premium center bolt cast iron
Hardened retainers and valve springs
2.02'' swirl polished intake valves
1.60'' swirl polished exhaust valves
Camshaft Specs:
Hydraulic Flat Tappet
Duration @ .050'' Lift: 229 Intake / 230 Exhaust
Lift: .480'' Intake / .486'' Exhaust
Cylinder Heads:
Camshaft Specs:
Received 3,043 Likes
St. Jude Donor '05
maybe the TBs do but doubt the intake itself does
Cylinder Heads:
Camshaft Specs:
Cylinder Heads:
Camshaft Specs:
I do have a stock and a ported. my TBs are stock and I have orig. ECM. I guess my question is more general or maybe out of curiosity . that engine if u buy it dressed comes equipped with a 600 cfm carb on it . the xfire will flow 570cfm so that's only a 30cfm difference. What am I missing?
Tuning of the intake for cam. May be possible to adjust fuel psiand spark for new can but what guarantees do you have that it would work
I guess my ignorance is in how the ECM controls spark. Because if the stock non ported manifold flows only 30 cfm less than the carb that Blueprint suggests to put on that particular engine how does the cam know if its coming from throttle bodies or a carb? I don't mean to beat a dead horse. just trying to learn .
B4 you invest $1000's in the car you own( I did) think of instead converting to a port mod injection system powered by EBL. I think the rewards are there. I run a Holley projection manifold with 7.4L TBI unit. I should have gone PF day one!
St. Jude Donor '05
Those intakes have a huge plenum they need more. Carbed much smaller plenum needs less.
Thats why you may see a tunnel ram with 2 large carbs. not that the heads/etc needs it so much, more the intake. hard to explain
Here is info on flow tests(note one barrel comment):
http://www.candsspecialties.com/ratings.html
http://www.fordfe.info/CarbMythFact.html
