egr and maf codes
Old 01-02-2014, 04:54 PM
pastamike
pastamike's Avatar
Default egr and maf codes
Is there anyway to test the egr and maf or just replace them..
codes, p0100 and p0400
thanks
Old 01-02-2014, 05:40 PM
GREGGPENN
GREGGPENN's Avatar
C4 of Year Winner (appearance mods) 2019
http://www.obd-codes.com/p0100
http://www.obd-codes.com/p0400
Old 01-02-2014, 06:29 PM
pastamike
pastamike's Avatar
thanks for the help will follow the links you gave and see what happens.
once again ty, pastamike
Old 01-02-2014, 06:32 PM
merlot566jka
merlot566jka's Avatar
Clean the maf...
but with both of those codes, I would be looking at a clogged cat...
Old 01-03-2014, 12:12 AM
leesvet
leesvet's Avatar
90% of ALL replaced MAFs were actually bad wiring or poor connections or relays. MAFs are pretty reliable. DVM on relays (if equipped) or follow FSM flow chart to test relay or control module circuits. The MAF plug itself is good for problems.
EGR....same deal. Dirty connections to the solenoid, egr ports caked with carbon and crud, bad vacuum to the egr or solenoid. EGR solenoids DO fail, but check the simple things before buying a new one. Its usually vac or solenoid elec connections.
BTW..
clean the MAF with a spray cleaner made for MAFs. DO NOT try to touch it (hot-wire)unless you are comfortable with delicate electronics...
Good luck
To egr and maf codes
Quick Reply: egr and maf codes
