How to get 30-40hp more from an LT-1?
Old 01-09-2014, 02:01 PM
GKK
GKK's Avatar
Default How to get 30-40hp more from an LT-1?
My friend who is new to C4 Vettes, is looking for a 95-96 C4 for a weekend toy.
He was thinking he could get about 30-40 more hp by Porting the stock heads and exhaust manifolds, Balancing the driveshaft and installing a transmission shift kit. Also, All mods have to be California emissions legal.
He's a retired old school wrencher and I told him I really didn't think so, but I'd ask here.
Old 01-09-2014, 03:22 PM
rklessdriver
rklessdriver's Avatar
A REALLY good set of ported stock heads and 1.6 rockers would put an easy 30-40 HP on an LT1....
Just look at the LT4... the only difference was a little compression, 1.6 rockers and better cyl heads. The camshafts themselves were pretty close.
With the LT1 since your pulling the heads to have the ported you can bump the compression a little by having the machine shop/porting shop deck them to 54cc's and install them with the Victor Reinz PN 5898 headgaskets (.026 CD).
The Advanced Induction 190 CNC package would be a good choice.
http://www.advancedinduction.com/LTX...rtStrpHead.php
Driveshaft balance has no bearing on improving anything unlesss he has a vibration.
Shift kit in the 4L60 is not a bad idea but again not going to add any HP.
Will
Old 01-09-2014, 04:22 PM
Orr89rocz
Orr89rocz's Avatar
Exhaust and a tune should get close to 30. Head work for certain
Old 01-09-2014, 04:31 PM
DanielRicany
DanielRicany's Avatar
A cam might get you there!
Old 01-09-2014, 04:56 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Ported stockers as will said even on the stock valves oughta do it, sneak a small cam in there.
even wiht the stock manifolds he should easily achieve if not surpass his goals. AFR makes some EO legal heads also
Guess it depends how good he is with a grinder and the final tune.
Dougs makes a pretty nice set of shorty headers that are smog legal for ca also bolts right up to the stock exhaust
Sniffer doesnt know if you have a cam or a larger crank in it fwiw
Old 01-09-2014, 06:31 PM
l88rocket
l88rocket's Avatar
good heads, 224/230 cam, headers, that's over 50 there
Old 01-09-2014, 06:53 PM
aboatguy
aboatguy's Avatar
shift points are controlled in the tune on a 1995.
Ported stock heads would pass the Kali smog ***** visual inspection.
Old 01-09-2014, 08:44 PM
GKK
GKK's Avatar
Thanks, everyone!...
I'll tell him to Port Away!...
To How to get 30-40hp more from an LT-1?
Quick Reply: How to get 30-40hp more from an LT-1?
