How much to have fuel pump installed?
Well, not just the fuel pump....one of these kits: http://www.racetronix.com/Racetronix...t-GSS307M.html
on my 94 lt1.?????
on my 94 lt1.?????
Re: How much to have fuel pump installed? (YellowFvr)
Just do the pump, and do it yourself. Takes less than an hour with basic skills.
Re: How much to have fuel pump installed? (Vette92)
I changed the fuel pump in my '85 in less than 45 minutes and I'd never done it before. It's so straight forward you almost will kick yourself for psyching yourself up for a big job.
The fuel pump is an easy fix (as Vette things go). It's a DIY, just don't light up while you're doing it.
I saw a write-up that recommended the wiring upgrade with the Walbor pump. Also a DIY, but it will take a little longer.
DIY then spend the savings on :cheers:
Re: How much to have fuel pump installed? (John Row)
I saw a write-up that recommended the wiring upgrade with the Walbor pump:
Re: How much to have fuel pump installed? (bill mcdonald)
I agree with everone here, the fuel pump install is probably one of the easier mechanical parts to replace on the car. As said before don't light up while doing it and also make sure you disconnect your battery.
Moderator
CI 5-6-7-8-9-10-11-12 Veteran
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23
Do it yourself. It's not difficult at all. It took about a hour or so to do the complete job on my '85. Just be cautions about having anything around that might create a spark and disconnect your battery. :chevy
Cruise-In II Veteran
Buy a pump and pickup screen and get some vacuum nipples to keep the fuel lines from oozing.
It realy is one of the "simple hand tools" jobs on a Vette.
