86 Convertible Deck Lid problem !!!
I put my convertible top down and when I went to put my top up only the drivers side of the deck lid releases. The passenger side will not open. You can hear and feel the actuator trying to release it but i can't open it. I tried pressing down on it while holding the release button but still not luck. I was fixing the plastic trim piece prior to this happening and had to fold back a little piece of the carpet, I was able to pull the carpet out and it still will not open. Is there any other way to release the lock so that I can open the convertible top deck lid to access my convertible top ?
Problem solved ! I ended up taking the 2 bolts off that is connected to the bracket that locks into to the latch. The other side opend fine. I found the cables buried under the rug. The reason why the lock would not release is that the cable came off the pin because the retaining press on washer fell off !
