What is my compression ratio?
Hey guys, I want to know what my compression ratio will be. I've been using online calculators but they seem to give me confusing and varying answers.
My car is a 1985 Corvette. The engine specs are:
Bore: 4.000"
Stroke: 3.48"
Head Gasket Bore Diameter: 4.100"
Compressed Head Gasket Thickness: 0.015"
Combustion Chamber Volume: 65 CC
Flat Top Pistons
Deck Height: 0.025"
Thank you!
Bore: 4.000"
Stroke: 3.48"
Flat Top Pistons
Deck Height: 0.025"
Thank you!
hey guys, i want to know what my compression ratio will be. I've been using online calculators but they seem to give me confusing and varying answers.
My car is a 1985 corvette. The engine specs are:
Bore: 4.000"
stroke: 3.48"
head gasket bore diameter: 4.100"
compressed head gasket thickness: 0.015"
combustion chamber volume: 65 cc
flat top pistons
deck height: 0.025"
thank you!
Bore: 4.000"
stroke: 3.48"
flat top pistons
deck height: 0.025"
thank you!
I read online in a few posts where people said the valve reliefs make up 4 CC, so I typed that into the calculator and got 10.28:1, would that be accurate? Then I can just say 10.3:1 CR.
Since you only have an estimate of your deck height I would say that's close enough for now.
The SRP flat tops used in my 396 were advertised as +5cc. But I've also seen flat tops with one long relief that were +7cc.
What heads do you have on your 85? Stock heads would be the 76 cc 624's. Your stock pistons should be trw forged units with a trough. Where are you coming up with 64cc combustion chambers?? Compression ratio on a stock 85 would be around 9.0, same as an 84.
Great choice!!
