2 cracks in block
2 cracks in block
I have a crack on each side of my engine between and flush with the top of the 2 center freeze plugs under the center exhaust ports. I flushed the system and put new anti-freeze in July. Is there some kind of "Band-Aid" I can do so I can figure out a new engine or do I just pull it . Thanks for any help.
they're about 4 inches long front to back of the block about 1/2 to 3/4 of an inch from head. Looks like top of crack sticks out about 1/16" . Is there something that will bond to it or would it have to be welded? I would like it to make it for a couple of months of minimal "fun" driving till I can get new engine together.
Received 3,043 Likes
St. Jude Donor '05
Toss it
I've seen blocks with casting imperfections that looked exactly like a crack.. I wouldn't pull it until you checked it out further...WW
Given all that, it would certainly be quicker get a reman short block and replace the old engine.
Testing the block would be a good first step. Rent a cooling system pressure tester and put a good 15-20psi pressure into the cooling system and watch the area to see if there is any coolant leakage. T
If you think about it the fact remains that a 4 bolt main is easy to find and for around $200. Call engine rebuild shops and they can sell you one that is inspected and ready to go. Good luck !
