HELP turn the key on and NO power Black
Old 03-05-2014, 07:04 PM
rays96in
rays96in's Avatar
Default HELP turn the key on and NO power Black
Hello every one,
Need serious help with this one. I had the key on and I was taking off my fan relay and I took a hot wire from pos terminal of the relay to one other terminal to see if my fan would come on and it did but the car got I don't no how to explain but my fans to radiator are on when the keys on. and they slowed down like a power serge.... NOW I turn key on and I have nothing acc nothing dash, radio nothing total black nothing comes on... Is there a fuse, fusible link something I blew. car has and does run perfect every day car. What the hell pulled steering column down and have power to the switch all fuse work good.. Any idea's
Old 03-05-2014, 08:48 PM
AGENT 86
AGENT 86's Avatar
Clean and tighten your battery terminals, then try again.
Is fan on with ignition on, a new problem or old problem ?
Old 03-05-2014, 09:00 PM
leesvet
leesvet's Avatar
well?
don't do THAT again !
AFTER you go thru the fuse panel and check each and every fuse...
THEN take the battery OUT, and the battery TRAY, and look at all the fusible links that live under the battery. They are the power source that has 'hot wires' to the jumper pole behind the battery toward the door jamb. These fusible links are the REAL power source for the DASH displays, the cabin/dash lites, the ECM and the fuel injection.
Sounds like you toasted one...or more. Replace links with the same value. They are rated like fuses. Your FSM will have the link values or you can find the tables for the gauge wire in that particular circuit and install the appropriate link.
Good luck !
Old 03-05-2014, 10:54 PM
rays96in
rays96in's Avatar
Yea thanks for the come backs, Leesvet that's what I needed to no. How many fusible link are there do you no? I got power every where but nothing happens when I turn the keys on same as off. Thanks for input.. Think of anything else please let me no. Thanks
Oh yea no ECM went to carb
To HELP turn the key on and NO power Black
Quick Reply: HELP turn the key on and NO power Black
