Service Engine Soon Light
Cruising
The service engine soon light comes on when I drive at highway speeds for about 20 minutes at times. It usually stays on until I stop the engine. When I re-start the engine it stays off. There is no code left on the ECM. The car runs great. I'm getting about 28 mpg and the engine is powerful. I'm running a turbo plate. I wonder if this is causing the light to come on? Any help would be appreciated.
Sounds like you are getting an error code 32 (EGR not functioning). You have the classic symptoms: SES lights after driving for a while at a steady speed. SES light is off after restarting.
Since it's not setting an error code, it might be turned off in the tune.
I had this classic symptom and then I rebuilt my engine. Everything was replaced EXCEPT for the EGR control valve relay. Turns out it was a broken header bolt leaking exhaust. This broken bolt became a priority and after it was fixed the light has not come on. All you can do is go through and inspect and or replace all the parts in the system. A couple hundred bucks in parts if you decide to just replace everything. Now some will argue this is not necessary and they have a point. However the car is over 25 years old and once you get the labor into the equation of solving the problem it just seems safe to replace it if its old.
Cruising
Reply: I installed a new heavy duty EGR valve and it looked like it fixed it for a time. Could it be the EGR Relay?
Cruising
On my car the EGR solenoid failed and that caused the EGR valve to carbon up and freeze so I had to replace both of them.
I tested the new EGR valve from AutoZone and it would not hold vacuum. I put a genuine GM part on my car and it has been fine for years. I have heard of other people finding new EGR valves that don't hold vacuum, so it is a good idea to check it before putting it on the car.
