Intermittent Low oil pressure..
Old 03-20-2014, 09:55 PM
violinsib
Cruising
violinsib's Avatar
Default Intermittent Low oil pressure..
Changed oil pressure sending unit....not the problem. Oiil pressure goes to less than 5 psi sometimes to 0. Recovers to normal for days, sometimes weeks. Oil temp is always normal when this occurs...car runs fine. Tried changing oil filter and synthetic oil but no change with the weird oil pressure symptoms. Don't know what to try next. It happens so intermittently that even if I went to the mechanic to check he oil pump the pressure would be normal and stay that way....that is until I left the mechanic then back to weirdness.
Old 03-20-2014, 10:17 PM
Deakins
Deakins's Avatar
Have you verified the pressure with another gauge (like an Autometer Pro Comp mechanical unit)? If so it may be an issue with the oil pump and or something obstructing the pickup temporarily; is it original? It's not too bad to get the oil pan off but I would make sure and verify that it is indeed hard part related before I did it. Just my .02
Old 03-20-2014, 10:24 PM
don hall
don hall's Avatar
It is recommended that you connect a mechanical oil pressure gage
to the engine to determine 'real' oil pressure.
A spun rod or main bearing can cause low oil pressure.
Old 09-10-2014, 12:35 PM
violinsib
Cruising
violinsib's Avatar
Disconnected oil sending unit and connected Mechanical oil pressure gauge; reading normal at all temperatures. However, puzzled that the dash gauge was still reading erratic while the mechanical gauge was hooked up. Where is the dash gauge getting its reading from? are there 2 sending units on this car?
Old 09-10-2014, 01:03 PM
19corvette91
19corvette91's Avatar
Sounds like your dash gauge is the culprit.....
To Intermittent Low oil pressure..
Quick Reply: Intermittent Low oil pressure..
