C4 interior lights
C4 interior lights
I have a 1990 convertible. Removed door panel and the interior lamp shorted out. All interior lights went and ac control readout. Checked all fuses on passenger side and underneath dash.... All good. What else can I check.
It's probably called CTSY/CLK (it is on my car, but you have the updated interior with the larger fuse panel so it might be different).
The fuse panel is on the passenger end of the dashboard. You have to open the passenger door to see it. There is a cover over it that must be removed (1/4 turn plastic ****).
