How do i find out what 'byte #' corresponds to my ac press output on a 93 da2
Old 04-03-2014, 03:30 PM
dizwiz24
dizwiz24's Avatar
Default How do i find out what 'byte #' corresponds to my ac press output on a 93 da2
I am currently datalogging my wideband o2 sensor thru the ac press.
Wideband o2 values show up in terms of ac pressure (when reading datalogs from datamaster).
I then have to convert it, using a linear conversion, to afr.
I am getting tired of converting it. Especially when i am being charged for my time on the dyno. This is an extra step and it slows me down.
I want to use datamasters 'custom data' function to have it show me afr. In order to do this, i need to know the 'byte #' in the code, that ac pressure is displayed on
Does anyone know what byte # is used for the a/c pressure?
Old 04-03-2014, 03:39 PM
FrankieD
FrankieD's Avatar
Try posting your question on GearHead EFI Forum, you will most likely get an answer there.
http://www.gearhead-efi.com/Fuel-Injection/forum.php?
Old 04-04-2014, 02:39 AM
Cliff Harris
Cliff Harris's Avatar
Maybe this will answer your question. From the DA2 .ADS file on the TunerPro web site.
http://www.tunerpro.net/download/datastreams/GM/DA2.ads
dwItemType =1;
strItemComments =<Comments>;
bSeparator =0;
bVisible =1;
dwUniqueID =1;
btByteNumber =20;
btMessageNumber =1;
dwItemSizeBits =8;
dwOperation =0;
dFactor =1.875000;
dOffset =-18.750000;
strItemTitle =A/C Pressure;
strUnitLabel =PSI;
dwAlarmHigh =255;
bAlarmHighENable =0;
dwAlarmLow =0;
bAlarmLowEnable =0;
iRangeHigh =255;
iRangeLow =0;
iLookupTableIndex =-1;
Old 04-04-2014, 08:20 AM
dizwiz24
dizwiz24's Avatar
dwItemType =1;
bSeparator =0;
bVisible =1;
dwUniqueID =1;
btByteNumber =20;
btMessageNumber =1;
dwItemSizeBits =8;
dwOperation =0;
dFactor =1.875000;
strUnitLabel =PSI;
dwAlarmHigh =255;
dwAlarmLow =0;
bAlarmLowEnable =0;
iRangeHigh =255;
iRangeLow =0;
Thank you!
To How do i find out what 'byte #' corresponds to my ac press output on a 93 da2
Quick Reply: How do i find out what 'byte #' corresponds to my ac press output on a 93 da2
