mixture control solenoid
Pro Mechanic
I don't think that there is any such thing. Early 80's Carb'ed engines had an MCS in the electronically controlled Carb...but not an '85 'Vette.
Where is this item located on the engine?
I had a mechanic check out my car, said it has something to do with emissions and said I should replace it. Could he have meant something else.
Pro Mechanic
Warning...Will Robinson!
I'd ask the mechanic from more details. Something is amiss w/either his diagnosis or your interpretation thereof.
He's probably talking about the IAC - Idle Air Control. Typically the passages in the throttle body get dirty and cleaning them will fix IAC problems in most cases (and not require a new IAC).
It's possible he's talking about the TPS (Throttle Position Sensor). They do need to be adjusted. They seldom fail.
Another possibility is that it's the EGR (Exhaust Gas Recirculation) valve. The EGR passages can get plugged up with carbon. There's also an EGR solenoid involved that controls it.
Pro Mechanic
Yep. COULD be one of many things....just a bunch of WAG's until we hear back from the OP.
I asked him to check the car because it has a hesitation on acceleration from dead stop, he meant the EGR solenoid. Said I could change it myself. Is it an easy job. Thanks
My experience is that a hesitation off idle is caused by a vacuum leak.
I guess an EGR valve stuck open would qualify as a vacuum leak. In my case the EGR solenoid was bad and caused the EGR valve to stick, so both of these need to be checked.
