How much does a c4 weigh?
Old 07-27-2002, 04:41 PM
jmrl98
jmrl98's Avatar
Default Re: How much does a c4 weigh? (C4ForGeeGee)
Wow boys, I have a pig! The corvette action center site says the curb weight for my '85 is 3540, and my door label says a whopping 3727lbs! It is a 4+3, and I suspect not having the glass top option to be a culprit, because I sure don't have anything else on it! :eek:
Old 07-27-2002, 06:31 PM
No Go
No Go's Avatar
Default Re: (95AquaC4)
95AquaC4...is that weight original or what? That would be the lightest late C4 I have heard of...70 pounds for gas and 165 for you...puts you at an 'operating weight' of 3021 pounds! That is like 200 pounds lighter than my original 96 coupe with one option-power drivers seat...hmmm.
For others...admittedly it is a not always convenient, but fill the tank up to the top before you weigh and subtract a full 20 gallons (or not)...seems like Corvette gas gauges are quite inaccurate...my 96 will read full with less than 9 gallons in the tank!
Please not meant to be flame...just would like to see some consistency:)
Old 07-27-2002, 09:12 PM
tkrussell
tkrussell's Avatar
Default Re: How much does a c4 weigh? (YellowFvr)
Why is the C4 so heavy? MY 69 convertible with 350, AC and a full tank of gas weighed 3220.
Old 07-27-2002, 09:18 PM
DragMan
DragMan's Avatar
Cruise-In VII Veteran
My car 3500 with 230 lb driver 5/8s tank of fuel no spare tire!
Old 07-29-2002, 12:28 PM
War Machine
War Machine's Avatar
Location: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: How much does a c4 weigh? (tkrussell)
The ABS unit is about 10 lbs. minimum, plus the C4's have all the emission crap adding onto the weight.
Old 07-29-2002, 08:49 PM
NavyVet
NavyVet's Avatar
My '96 CE roadster weighed in at 3493 with a full tank of gas, spare, and 315/35s all the way around at a SCCA Nat'l Tour event a couple of months ago. Oh, I was standing alongside it :jester
Old 07-29-2002, 11:53 PM
ICANTDR55
ICANTDR55's Avatar
how is it you guys vettes are so light? my vette with me in it and spare, and full tank of gas weigh 3580. where do you guys have your vettes weighed ? i weigh 220 lbs. I had know idea that a 92 coupe weighed so much. :(
Old 07-30-2002, 12:11 AM
Torqued84
Torqued84's Avatar
Default Re: How much does a c4 weigh? (Zora)
Some of you guys need to come out to the southeast and get some buttermilk biscuits and gravy. Put you on at least 10 more pounds :cheers:
Quick Reply: How much does a c4 weigh?
