Low beam/Fog light issue
So my Fog lights and low beams both do not work on my 85, High Beam works fine and i've replaced both headlights and both fog lights no blown fuses either?? i've read that its possibly the dimmer and headlight rod although noone seems to have the problem of both headlight low beams not working... the sockets are not corroded either
Could these possible be related to my turn signal switch being bad??? my hazards work fine but on my dash both turn signal lights are lit up and they will not turn with the lever tilted either way
Sounds like you have a problem in the dimmer switch.
Have you always had this problem or is this something new? It's possible you have the wrong headlight switch.
