Best distributer for modified 85..?
Old 04-23-2014, 03:41 PM
Ziggy91
Ziggy91's Avatar
Default Best distributer for modified 85..?
So I just sold my 85's L98 and I'm almost ready to swap in my new Vortec
I'm still using my 85's harness and ECU but need a new distributer since the old one is sold with the L98. I don't want to buy a $500.00 unit when the $150.00 one would be good enough. Any recommendations?
It's a bored over .60 350ci with an Edelbrock Pro Flo, Vortec heads, CC 1.5 roller tip rockers, CC 262/270 cam, Scat rotating assembly, running 10:1 compression. I suspect 300hp at the wheels so nothing extreme.
Help is always appreciated.
Old 04-23-2014, 03:58 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
My prior '88 was building ~300chp and shifting at ~5,800rpm so I wanted plenty of spark in the hole and chose HyperTech coil/cap/rotor: link
This allowed me to open the gap to .045" on my stock cut-back plugs.
Old 04-23-2014, 04:15 PM
WW7
WW7's Avatar
I figure I have around 340 hp at the wheels and Im using a DUI distributor in my 383.. To be perfectly honest the only reason I bought the DUI is because my old distributor had a lot of miles on it and when I put in the 383 I wanted all new parts...The DUI uses a stock Delco Remy body but they put in there higher output coil and ignition control module...It's a nice unit for the money...Really the stock distributor would be fine for what you have , the stock units put out plenty of power for your car and it would work just fine.......WW
Old 04-23-2014, 08:19 PM
cumbercr
cumbercr's Avatar
I went with DUI in my 85. Unfortunately, the DUI coil caused my tach to be erratic. There's nothing wrong with using the stock distributor.
Old 04-23-2014, 08:24 PM
WW7
WW7's Avatar
It's strange that you would say something like this , because when I installed the DUI distributor my knock counts increased, I replaced there coil with a stock type coil and the knock counts lowered.. I just left the stock coil in and never messed with it to find out why this happened..I completely forgot about the incident until your post sparked my memory........WW
Old 04-23-2014, 08:41 PM
1985 Corvette
1985 Corvette's Avatar
Craig, Jim mentioned the same deal running a stock distributor with his at-the-time 450. I need to pick one up. I was planning to pick one up for cheap on here and do a basic refresh.
Old 04-23-2014, 09:01 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
I have never had an aftermarket ignition outperform a stock HEI. That's not to say that non can or will, but I've never seen it happen and the stock one is incredibly reliable and good working.
Old 04-23-2014, 10:10 PM
cumbercr
cumbercr's Avatar
That's interesting. It didn't occur to me that I've been able to add timing since I installed the stock coil. I thought it was because I upgraded the ECM.
Old 04-23-2014, 10:12 PM
cumbercr
cumbercr's Avatar
I forgot to mention that I've had two DUI coils fail. They never go bad when you're close to home.
Old 04-23-2014, 10:49 PM
gerardvg
gerardvg's Avatar
The standard distributor will be fine, i have never had a problem with the distributor in my 85, it has no problem with my supercharged 383 engine and you can easily make adjustments to suit highly modified engines with TunerPro and a Moates ostrich emulator on the fly no need to remove chips.
http://www.tunerpro.net/downloadApp.htm
http://www.moates.net/aldu1-and-cabl....html?cPath=64
http://www.moates.net/ostrich-20-the....html?cPath=64
Old 04-24-2014, 06:56 AM
WW7
WW7's Avatar
I keep an emergency bag of parts in the locker behind my seat, some of the things I carry are an extra "Coil", "ICM", and more recently a "Vats bypass module", ..These 3 parts can save your butt if your away from home and disaster strikes.... ......Last year I saved another C4 owners azz at a car show by having the extra ICM in my car , I gave it to him for what I payed and replaced it immediatly when I got home.....WW
To Best distributer for modified 85..?
Quick Reply: Best distributer for modified 85..?
