Bose Radio woes
7th Gear
Bose Radio woes
Hey guys! I have a 89 coupe with oem Bose Delco stereo. I've read countless threads on how horrible this radio is and ways to diagnose issues. I can't seem to narrow down a "plan of attack" for my problem.
turn radio on - displays correctly and tuning works - antenna goes up as well - sound out of all speakers but driver's side door - within 2 minutes all sound stops - radio still displays and tuning works
Does this sound like a Bose relay issue or radio overheating? I'm hoping this is a quick fix...Any help is appreciated!
btw recently replaced battery, plugs, wires and cap and rotor
Cruise-In II Veteran
Unless you have a "bench" about all that can be done is to check all fuses and electrical connections. If you want to keep the OEM look Dr. Don, though a bit expensive, is used by many for repair or replacement with a repaired OEM unit.
I just repaired my 4 Bose amps on my '89 coupe. I love the Bose sound.
My 2001 Maxima, 2093 Suburban and 1981 300zx all have the factory Bose and it sounds great.
From what you describe, I would think it's the head unit. Can you hear any noise from the other speakers?.
Pull your center trim panel and the center console cover. Remove the A/C control unit (4 7mm screws) and reach under the radio to check to make sure the connections are tight. If they're all good, pull the radio out and try spraying some contact cleaner inside.
There are units on ebay as well as some shops that will test your head unit.
Did you try a tape or a CD.
Do you hear any “noise or hum” out of any speaker when you put your ear right up to it.
Do you get any pop out of any speaker when you turn on the on/off control on and off.
