Optispark base timing?
Old 05-05-2014, 05:42 PM
MrWillys
MrWillys's Avatar
Default Optispark base timing?
Does anyone know if the Optispark has any initial timing built into it, or is it set at zero?
Old 05-07-2014, 08:47 AM
dizwiz24
dizwiz24's Avatar
Im pretty sure its 0....all timing is commanded by the pcm.
Old 05-07-2014, 11:24 AM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
Mechanically, it has to be set at "0" b/c one of it's primary functions is to tell the ECM where TDC is on each cylinder. Each low res window should clear the light beam at 0*/TDC for each cylinder.
To Optispark base timing?
Quick Reply: Optispark base timing?
