LOL They probably sent you the bad opti I just took back! sorry. I bought one 7 months ago. It went bad...they forgot to put a seal inside the unit. They sent me another...Still got a code 16. Took it back and got a full refund no questions asked. I Bought a Chandler Motorsports opti off Ebay for $110 and the code 16 went away. My car is still not reliable. I have an intermittent code 15. I believe it to be the ECM. That's a whole other story. If there's a code 16 set, then there is a problem with the opti.
I wanted to say this. You could have it fingerprinted and see if ours are on it.
Well, after much testing I've finally come to the conclusion that my Petris opti is also bad. I've done every single test both from the FSM and from Petris troubleshooting doc. I checked all grounds and even sent my ECM out for testing; it came back without defect. I hate to think that this thing has to come out again.
