Very rough idle
Very rough idle
Bought my 87 late last year and it always had a rough idle. Did a complete tune up including new distributor. Just finished putting new intake manifold gaskets in. New EGR valve and oil pressure sensor. Ran and idled great. Parked it for a few minutes and then when I started it back up, it was idling worse than ever. Runs great when driving. What to try next?
you didn't mention the iac....have you checked it/replaced it?
1 check for codes first
2 make sure your NEW egr valve is working
3 check your Iac
4 check tps/ min idle adjustment
5 get a fsm...gm.....check fuel pressure
good luck....
3 check your Iac
good luck....
