Clutch Pedal Postion Switch Adjustment?
Just completed a master cylinder swap on a 93LT1 which has gone horribly, but seems to be under control now. It seems one of the casualties may have been the clutch pedal position switch. I push the clutch in, no start. I jump the connector and it fires right up. Is there a way to adjust this switch? Is it common for it to come out of adjustment when you are moving the pedal all around every which way? I did accidentally pull the pedal all the way up and the cruise control switch slipped almost all the way out, would that break the position switch? I cant find anything in the FSM about it and it doesnt look fun to remove/replace.
Hmm, didnt think to actually watch if the switch was moving. Everything looked connected. I did fix the travel problem, I somehow managed to get the slave push rod up over the fork so everything was all maxed out. I moved the floor mat and everthing and still nothing on the switch. I guess I could test the connector, it should go from open to closed on a continuity test right? See if its toast or just needs some more travel....
