Flywheel balancing ?'s
I have a McLeod twin disk setup for my ZF6. I sent the flywheel in with my crank to be balanced. (many years ago) Now that I am getting ready to install it, I was checking to see if I still have all the parts together. There was a big counter weight attached to the engine side of the flywheel. I have it and it isn't installed on the flywheel. My 383 is using an aftermarket crank and should be internally balanced. Was that weight for an externally balanced engine, or did my machinist remove it because he balanced it all? Any ideas?
The "should be" comment you made is the suspect part. Did you ask for an internally balanced build?
Did you buy the 1345 series hydraulic release? Would you mind a snapshot or two of the attachment to the front guide tube retainer if you did do the 1345 series.
Well, it was many years ago. Life through a few curve ***** since then and that is why this project has been going so long. I can only assume as to what happened at this point. I would not have asked for an externally balanced engine. I guess I was just looking for a little reassurance.
1345 series? LOL, I don't think it was even an option when I bought the twin. Mine came with a different slave cylinder, that's all. I have a traditional pressure plate. Sorry.
What are the advantages to the hydraulic T.O. bearing?
Pro Mechanic
Take your current FW w/the new one to a machine shop. Have them confirm that they're the same balance.
I would go down the road w/WVZR-1 first...but iff you can't be certain about what you've got and what's been done, try my suggestion. I'd be pissed if I had to pull my FW again due to engine shake.
All the "old" stuff is gone Tom. This block and reciprocating assembly is all new or different. The 383 crank is made for internal balance. I think I still have the balance sheet but I don't remember it saying much other than the bobweights.
If it's indeed "neutral" now I would think you could be correct in assuming that it's the way it was balanced BUT there's the who knows! Was the plate bolted to it when you gave it to the shop? If you know for sure yes then more reason to assume it was removed to accommodate the internal balance.
The 1345 series changes the clutch to a push VS. pull style clutch assembly.
