ls swap wrong balancer?
[Sloved] ls swap wrong balancer?
I almost have the LS fully bolted into the car, and i noticed that there is no room for the belt under the harmonic balancer. Is an smaller balancer needed? If not what balancer should I be using?
There is a lot left to do, but I don't want to add anything else if I need to pull the engine and change the balancer.
The balancer is from a c5.
Update
I solved it by swapping the mount adapters left to right.
Update
Why didn't/don't you post in it and ask your questions about C4/LS conversions there?
How can you have clearance for the harmonic balancer but not enough for the drivebelt which sits in the pulley/grooves? Can't you lift the engine by a quarter of an inch and slip the belt on?
I have a 25% underdrive pulley on mine with about 1.7 inches of clearance under it. I didn't try installing the engine with the stock crank pulley.
Your engine probably sits a bit lower than mine too.
I made this thread last week http://forums.corvetteforum.com/c4-g...-your-c4s.html
http://forums.corvetteforum.com/c4-g...lsx-swaps.html
As mentioned there are UD pulleys, or you can space up your motor mounts. Many of the SFI balancers are slightly smaller and safer.
I have a 1993 6 speed. The engine is afaik a early 2000s 5.3.
I have Doug's Headers Engine Swap Mounts SK100.
I did start look at a few of the swap threads, and they looked helpful but I did not see any mention of what balancer was used.
It looks like a lot of the swap pics use the same diameter balancer?
Later when I go to do some work I will measure the balancer, and double check how I installed the mount adapters.
When I did the swap on my '92, the stock rubber frame mounts sagged so much the balancer hit and the old pan was close. I ended up going with Solid mounts from a forum member and the ATI SFI balancer and have enough clearance now.
I imagine the 5.3l came out of a truck, did you keep the truck spacing on the accessories with the truck balancer?
The mounts are about 1 and 1/2 year old factory replacements.
I did not keep the truck spacing, and changed to a c5 or maybe c6 balancer.
It also looks to me like the mount adapters I used place the engine lower then the adapters I see others using. I might need to swap them left and right.
Update
It is about a 7.5inch balancer.
Update2
Here are some blurry pictures
Update
Update2
