87 fuel pump and relay wire colors (schematic?)
Working on a friends 87 vette, spark but no fuel pressure, pump not activating. Have it narrowed down the fuel pump relay.
On the relay - Orange Line (E) has constant 12v and GRN/wht Line (C) powers on for the 3 seconds.
The tank sending unit has (3) wires BLK, Pink and Brown w/wht stripe.
Trying to determine what color wire powers the pump to test the relay...right now don't have any power to the tank pump.
Cruise-In II Veteran
Here's the setup on my '88
FP Relay:
Dk Grn/Wht = relay enable from ECM
Blk/Wht = Ground
Orn = +12Vdc, in always hot
Red = FP power out to FP Fuse
FP Fuse (10A):
Red = +12Vdc, in when FP called for
Tan/Wht = +12Vdc, out to FP
Fuel Tank Unit:
Tan/Wht = +12Vdc, power to FP
Gnd (looks like case)
Have you checked the FP Fuse? If so check for +12Vdc on the Red wire & Tan/Wht when FP called for.
FP Relay:
Blk/Wht = Ground
FP Fuse (10A):
Fuel Tank Unit:
Fuse is good...so it looks like the 10a fuse is powered by the relay red wire which sends 12v to the pump via the tan/white?
If so, I should be able to jump the relay "orange" to the "red" temporarily to see if the pump gets 12v. Indicating a bad relay?
Ed
This is a massaged version of the picture in my '86 service manual. The FSM does not show the FP fuse, so I added it:
This should be the same setup for an '87.
