how does water pump relieve pressure on startup if heater core is gone.
About to install oil cooler and the adapter goes where the filter is which is connected to the "stock oil cooler" (which is entirely useless). If I take out the stock water-oil cooler, I already eliminated the heater core, and cap off the heater core output on the water pump and plug the inlet to the intake manifold how does the water pump eliminate pressure? The thermostat will be closed and pump will be spinning pushing on it. I know ive seen plenty of hot rods that only have the two radiator hoses, how do they do it?
Or is it really not that much pressure? Or should I run a line from the pump to the secondary inlet on the manifold? Can I just plug these things and be done with it?
What year car? There is a bypass in the block for most sbc, no clue on LT. The bypass is the hole just under the lower water pump bolt on the pass side. I always plug this bypass in the block or pump if the pump even has it(a motor plate will block it right off) and use a rear line out of the intake to over the T-stat or into the suction of the pump. Good thing tpi vettes have the line out of the rear intake already.
Its 1989. Word of the day, cavitate. That makes a lot of sense and interesting. I assumed it was a turbine of some sort not a centrifugal system. Im plugging those babies off today and getting rid of all the stupid extra lines just waiting to fail.
