Dimmer Lever location, rear side at T/S Lever
On my girlfriend's '92 coupe I am putting together the steering column at the Turn Signal Lever location, and I am trying to figure out where the Dimmer Lever goes in that area to be operated by the L/S Lever. I can see where it goes into the white plastic switch, under the dash, on the front side. At this point, it looks like the dimmer lever is too far from the T/S lever, even after I close up the gap on the top column cover to the column.
I would expect to find a little pocket on the T/S pivot switch that the dimmer lever would fit into, but don't see anything like that.
Thank you for the help.
I can't do you any snapshots but it should be pretty straight forward if the rod, the switch and everything is secured. Do you have the pivot/wiper switch installed and is all of that operational?
Here's an older link, I read it through and having done it a time or two I followed the way this was explained. I would think you'll catch on.
http://forums.corvetteforum.com/c4-t...-actuator.html
I found a helpful video showing the placement of the 'Actuator, Dimmer SW Rod'.
It looks like I am missing the following parts that I hope to get from a GM dealer this week.
- Rack, Switch Actuator
- Spring, Rack Preload
- Pin, Pivot
I saw this on Figure 1 - Tilt Steering Column, page 3F5B-2 of the '92 FSM.
- Pin, Pivot
how to rebuild a tilt steering column video #7 - YouTube
- Pin, Pivot
- Pin, Pivot
The rack and the spring will be no trouble.
These are good photos that was provided to me from a guy on the facebook C4 Corvette Forum.
The top photo shows the 'Rack, Switch Actuator' and "Pin, Pivot' that I don't find in my parts.
Here's the entire tutorial:
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
If this car cranked and ran before you started these parts should certainly have been there.
There are some snapshots here that should look very familiar to what you saw on disassembly. I don't know how far you went into the column but I wouldn't have thought you needed to remove the ignition rack that you mention is missing.
http://www.superchevy.com/how-to/vem...teering-wheel/
Today the parts department at the Chevrolet dealership said the '92 had two different Steering Column part numbers for that year, 26024008 & 26030970.
The parts needed depend on the S/C part number in the car.
So far I have not been able to locate a part number on the Steering Column.
Any ideas where the Steering Column part number is located?
7827157 is the rack, 7804908 is the spring for the rack and the pin like I mentioned, for a new one you will need to buy a kit. The kit for the earlier column is discontinued I believe and the only kit that is available is for the 0970. It's an expensive kit to buy for only needing a pin that I can't image isn't there.
Here's a thread with some pictures and another thread that describes the multifunction switch and the pivot mechanism which operates the dimmer rod. In this thread the pivot point was broken which is not your problem but the thread has some good pictures .
http://forums.corvetteforum.com/c4-g...h-replace.html
