95 with Service Ride Control light?
FX3 system. I checked for codes,only had an old H27 code. I cleared that one. Started car and Ride Control light still on. Checked codes again, and nothing, just C12.
Ay ideas?
Ay ideas?
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Yes, I read that first before porting, didn't really help, unless my controller is out, but I think that is unlikely but coud be. I guess that woud not set code?
Ok, you are correct, found another post that says ground 3 to 4 or 5, but I tried, and only thing that gives me codes is 4/12.
http://forums.corvetteforum.com/c4-g...-light-on.html
Post 8
Post 8
Yes, I have a FSM. Wondering why I am not getting into diagnostic mode when I do the 3/4 or 3/5? Only when I do the 4/12.
I have not driven it since checking yesterday and today, so I do get the C12 code, but that is when I do the 4/12.
Took of front actuators, they are good, but right shock rod spins freely when I turn it, and never stops. I think all shocks are good, as far as dampening, but this one just won't adjust.
The rod spinning, does not affect the shock, other than changing the settings correct?
Now I have to figure out what I want to do. Already had the shocks rebuilt once, rods replaced, and revalved to marraca setting. I think I am going to go to a softer standard shock.
