Head / Cam TPI Combo
I have a '90 l98 6spd car i want to upgrade cam/heads on. I have settled on the AFR 180's after considering Trickflow 175's (to keep compression up). The 90 cars are supposed to have 10.25:1 so the 65cc heads will take me down some, to about 9.5. I plan on running a .028 gasket to get some back, and i'm looking at a cam i think will be a good compliment to the car and heads, specs below. The car already has upgraded TPI hardware, AS&M runners, Accell base, ported plenum. The exhaust is Hooker SuperComp 1 3/4 long tubes and Corsa catback. Also have 1.6rr already in place and the car runs well. The cam is the Lunati Voodoo 262, i don't see many people here running it but it would seem to be a good fit, seems very much like the lingenfelter 211. This cam by my calculations would give me right about 8.00:1 DCR which would be good, and fit the modified TPI well. This would seem to be a good fit to me, am i missing something? Any input appreciated before i start spending $$$ :-).
Hydraulic Roller Cam. Great choice for stock to mildly modified engines, works well with OEM style injection, great inboard /outboard marine cam for economy and skiing. Good mileage and torque increase.
Advertised Duration (Int/Exh): 262/270
Duration @ .050 (Int/Exh): 211/219
Gross Valve Lift (Int/Exh): .507/.515
LSA/ICL: 112/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1600-5600
Includes: Cam Only
LSA/ICL: 112/106
Includes: Cam Only
Jim,
I love your setup.
Any thought towards having your 113 heads ported to bypass the compression 'issue, keep the 58CC chambers? My brother has a similar setup (Big mouth, AS&M runners, 1.6's, TPIS Headers etc) on his '90 and we are discussing similar head/cam options. I like the idea of sending his heads off to Lingenfelter for their CNC job or another reputable porter and be done with it.
I love your setup.
i though about that and inquired with TPIS. They want $1250 to port and redo the heads. I believe Lingenfelter is a little higher. That's just a little less than brand new modern heads. i don't want to put that kind of $$$ into 113 heads. I only want to do this once, if i do it again it's because i'm doing a 383, and the AFR's will translate over better then the 113's. That's why i was originally looking at the Trickflow 175's. They amount to ported out 113's but are more modern, and brand new.
Check out Fel-Pro 1094 head gaskets. 0.015" compressed thickness, and with stock deck height usually at 0.024", that puts you at 0.039" quench area which is perfect for running a good amount of timing. And it'll boost your compression up some.
Received 3,043 Likes
St. Jude Donor '05
That Lunati oughta pass smog no problem
Jim good combo you got planned there dont change a thing;sounds good
bout the only other thing you can do is take the grinder to the base. Not huge gains but they are there...or do it later if you want a little more
Spend $ on the tune it will pay off.
