Need some tire help
Need some tire help
This winter, I will be putting new tires on my 95 Coupe.
The door sticker states for tire size;
Front P255/45/ZR17
Rear P285/40/ZR17
Some previous owner put the following tires on this car;
Front P235/45/17
Rear P245/40/18 **Notice 18 "
What was some previous owner trying to accomplish with the tire combination's he put on, especially 17 inch on the front and 18 inch on the rear ? The car really handles well with these tires.
Thanks for your thoughts/opinions
8Valve
Front P255/45/ZR17
Rear P285/40/ZR17
Front P235/45/17
8Valve
Front P255/45/ZR17
Rear P285/40/ZR17
Front P235/45/17
8Valve
Front P255/45/ZR17
Rear P285/40/ZR17
Front P235/45/17
8Valve
Without that information it's near impossible to guess why and also impossible to offer up suggestions. You can't plan a tire purchase without the information. The wheel, what little can be seen in your Avatar suggests maybe C5 ZO6 knock-offs or maybe the real thing. They're black "something" until you remove and get the information!
You need to pull a front and a rear from the car and likely on the back-side the wheel width and the offset will be cast into the wheel. With that information it would be much easier to try and explain your options and maybe the reason why.
Thank You
8Valve
