Need Some Help Troubleshooting A/C
Old 07-26-2014, 04:37 PM
cumbercr
cumbercr's Avatar
Default Need Some Help Troubleshooting A/C
My A/C has been working fine until it suddenly started blowing hot air. It was converted to R-134A years ago. I thought maybe there was a leak or it was low on refrigerant. I bought a bottle of R-134A refrigerant with the gauge and connected it up to the low pressure port on the air drier. The compressor ran briefly and then shut off. The pressure was 150psi. What would cause the low pressure side to be at that high of pressure? The FSM is of no help here.
Old 07-26-2014, 05:22 PM
cudamax
cudamax's Avatar
Get a Little wire and jump the low pressure switch. Just locate it pull it off jump it and leave it disconnected and see what pressure ur at. It might be 150 because the clutch isn't engaged and running the compressor. Don't run it that long jumpered. Maybe 15mins tops and if it goes to a real low pressure while its jumpered Its low. put some more in
Old 07-26-2014, 05:30 PM
cudamax
cudamax's Avatar
If its a 150 with it jumpered and the compressor running do not add any because it's screwed up. Something let loose and plugged up most likely ur orfice valve/filter for starters but most likely it was a leakdown and hope for a real slow one u can't find then u can pump it up and you'll be good for another 2yrs
Old 07-26-2014, 06:19 PM
cumbercr
cumbercr's Avatar
I jumpered the low pressure switch and the compressor engaged. The pressure dropped from 150psi to about 45psi. According to the gauge that's a full charge. I removed the jumper and reconnected the switch and now the A/C works. Go figure. Thanks!
Old 07-26-2014, 06:25 PM
cudamax
cudamax's Avatar
There ya go I hear those low pressure switch connectors go bad a lot and if its not going lower 45 psi at about 2000 rpm its overcharged and will discharge a higher temp. You need it to pull lower to get colder
Old 07-26-2014, 06:44 PM
cumbercr
cumbercr's Avatar
So bleeding off a little Freon might make it more efficient?
Old 07-26-2014, 07:03 PM
cudamax
cudamax's Avatar
Yea get it down to about 28 to 30 at a steady 2000 rpm but make sure it isn;t there now Buzz it up and check first
Old 07-26-2014, 07:30 PM
cumbercr
cumbercr's Avatar
Will do. Thanks, you've been a big help.
Old 07-29-2014, 09:50 PM
cumbercr
cumbercr's Avatar
You nailed the problem. It's the connector. I've checked the Corvette parts sites but can't find one. Any ideas?
Old 07-30-2014, 01:49 AM
cudamax
cudamax's Avatar
Quick search on google got me this and their is plenty more
https://www.google.com/webhp?sourcei...ector&tbm=shop
and thanxs man no one ever says that anymore
Old 07-30-2014, 01:56 AM
cudamax
cudamax's Avatar
and for 20 bucks I think this is what u got
https://www.google.com/webhp?sourcei...62712605512275
Old 07-30-2014, 01:58 AM
cudamax
cudamax's Avatar
And A/C Delco replacement connectors
http://www.jcwhitney.com/ac-delco-oe...=d255y1994g2j1
Old 07-30-2014, 08:56 AM
cumbercr
cumbercr's Avatar
Thanks again. It's on order.
To Need Some Help Troubleshooting A/C
Quick Reply: Need Some Help Troubleshooting A/C
