1986 Headlight Assistance Needed
Hi everyone: I turned on my headlights last evening, and the driver's side only rotated about 2 inches. The light will come on, however it barely moves more than a couple of inches. I tried to manual get it to open by applying a little extra force, but no luck. When I turn off the headlight switch, it will return to the normal parked position. I do have a factory service manual, however it wasn't much help. Is it time for a new internal gear(s)?
Thanks, Chris
Thanks, Chris
gears or bushings... take your pick...
Either way, nearly 30 years on, not bad.... not bad at all.
Do both lights with a full rebuild and you won't have to worry for a long time to come.
Thanks, Chris
Thanks, Chris
Regards, Chris
