c4 distributor
My '88 has the two. If I got a distributor with one, I would think it is the wrong distributor and look for a two connection one. I assume that both plugs will not connect at the same connector.
You need a 4 pin connector to connect to the ECM so it can control the spark advance.
The 2 pin connector goes to the power and ground pins in the distributor cap.
