Bleeding brake caliper
Cruising
When bleeding the rear brakes I get fluid to the caliper but cannot draw any fluid out through the bleeder value. I have never had this problem before on bleeding brakes.
I see that this is you first post. There is also nothing in your profile so you need to state what year car it is to get valid feedback.
There is a possibility the bleeder valve is clogged with dirt.
The flex line could be the problem.
Or the ABS could be clogged but certain years are more prone to this problem so need to know year.
Ozz
