1994 C4 Hood wont stay closed
Good Morning. It seems as if there is an issue every day!!
The left side of the hood will not stay closed and popped while I was driving yesterday. I drove it home immediately (so much for taking it out over LDW)
The mechanic earlier in the day made a call for replacement parts but advised they have been discontinued. Could anyone help? I will need the two latches and the cables
PRODUCT CODES:
1025-0486 CABLE
1027-3994 LATCH
Thank you !!
PRODUCT CODES:
1025-0486 CABLE
1027-3994 LATCH
Thank you !!
If you check the parts for sale section of the forum you'll "breakers" like "See4Parts" and others. Contact them I'm sure they have good used parts that you can use.
Open link and scroll to post # 29 (Cliff Harris) for adjustment of latch.... may help (?):
https://www.corvetteforum.com/forums...ustment-2.html
Cruise-In II Veteran
A very simple adjustment. Just proceed slowly with adjustment till hood latches frimly but still releases.
The latches on my prior '88 were pretty well beat up but such adjustment still gave a solid latching.
just an FYI- i received help from Wally at corvette generation. BIG HELP since no one makes the full kit anymore
http://www.corvettegeneration.com/
Parts
I definitely recommend Pat (See4Parts). I've bought a number of items from him and have had great results.
