Setting up D36 ring & pinion
Since the shims are inbound of the carrier bearings, it's more involved setting up the D36. You must pull and re-press the bearings each time you adjust the amount or position of shims.
Are there special tools or methods specifically for this type diff to make the process less difficult and time consuming?
Any write ups on the process?
Thanks.
Thanks.
Thanks.
Thanks.
Sounds like a worthy plan as long as all carrier bearings for the D36 are the exact (or close) thickness.
Are they?
Are they?
Yes, they will work fine. Just verify the final clearance with the new bearings installed. Back in my mechanic days I kept several modified bearings for setting up GM and Dana rear-ends. It's a pain to pull the new bearings to move a shim with the proper tools and still risk damaging the new bearing.
Would anyone like to sell me a pair of honed carrier bearings I can use for my set up?
Or, I can send you shipping costs and you could loan them to me, then I would ship them back.
Considering the existing bearings are in good condition, I was planing on reusing them. I've had gear swaps done on three other vehicles in my days and never replaced carrier bearings. Pinion bearing maybe, but not carrier. Always reused them.
Your previous installs were likely Eaton style units where the shimming is done in the bearing cap "outside" the carrier bearings. The Dana is done inside between the carrier and the bearing.
In your original post you seemed to understand the procedure but I don't get your desire to save the $30 or so $$'s involved in the purchase of new bearings. You actually should buy an install package, six bearings, three seals and the incidentals included.
If that's your plan there's no need in borrowing anything. Bolt your ring gear to the carrier "as is" do your pinion install properly and see where you end up.
Would it help to hone out the old pinion bearing and use it for setup as well?
You're installing a "thick gear" on a 2 series carrier or? Your gear kit is new or? If yours is presently apart you might offer up some measurements to this thread:
https://www.corvetteforum.com/forums...-is-loose.html
Use the carrier "as is" to establish where you might be before pressing everything off of it and starting from scratch. The bearings are there so there's no reason not to. It's customary also to start with the same shim that is present on the pinion rear bearing also for the first go and then check the pinion depth.
Thanks for the tips. Most likely I'll have a guy up the street from me do the ring and pinion install but I'll be removing and installing the carrier from the car myself.
The 3.54's I have are a thick set designed to on to my 2 series carrier. (currently 2.59)
I've got all the parts including new bearings, seal and shims. What I dont see is a crush sleeve. Am I still missing this part or does the D36 not use a crush sleeve on the pinion?
Richmond Gear for the ring and pinion set.
Ratech for the install kit. # 348k. It has ring gear bolts and washers. Carrier bearings, races and shims. Pinion bearings, races, shims, pinion nut and seal.
No crush sleeve.
No crush sleeve.
Pick up the phone and call Richmond, Richmond years ago duplicated the OE's use of bearing fitment. If it was shimmed originally that's how they did theirs. Today? Just make the call. I'd have both the gear kit part # and also the # from each component. I believe both will be marked. If not use the Richmond information links to change the kit part # to the content of the kit. I believe that can still be done on there web-site.
alternative limited slip units for Dana 36
OK, I'm hijacking this sleeping thread. I tried a search for info on an alternative posi or torsen type for a D36 with no luck
This is for an autocross car. I'm going back to a D36 to get the 2.59 gear.
Don't like the D44 3.45 gear ratio that I'm running.
Is there anything other than the OE posi for a Dana 36?
TIA
TIA
I'm sure there are a hundred guys on this forum that would love to swap you straight across with no hassle. Hopefully you can find a local guy. and be done in an afternoon.
Yeah, I'm sure they would. I've got the D36. If/when time comes to dispose of the D44 it will not be a trade for a D36
2021 C4 of the Year - Modified Finalist
If you think you would be happy with a 3.08 instead of 2.59 you can get a 3.08 for the dana 44.
http://www.mcssl.com/store/ikerds-in...d10aa198fa2429
I would give them a call.
Appreciate that but I ran the 2.59 for years and was happy with that. I could run most courses in 1st gear so I'm going back to it. Not so happy with the 3.45 in second gear (LT4 w/700R4)
